EFI to CARB question
Old Jun 20, 2009 | 11:16 AM
trblsmeFC's Avatar
OK EFI to CARB question
I am changing to a carb'd setup on a s4 NA
I know i have to install a fuel pressure regulator, but im stuck on the ignition.
What do i do about the distributor, can i simply replace the existing one with one from a 12a or will i need to replace the front cover on the engine to one of a 12a also. Another question is will i still need both my trailing and leading coils, becuz the 12a engines came with 2 coils not 4 like that of the s4 engines
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
