93 rx7 headlight issue
Old Jun 18, 2009 | 01:12 PM
subiedude03's Avatar
My headlights dont turn on or flip up when I turn the switch. When I hit the headlight button they come up and when I hold the brights back they come on but the headlights don't do anything. Do you think this is a fuse issue? or a relay issue? Which fuses should I check? I just need a little help, thanks guys
Old Jun 21, 2009 | 05:38 PM
since no one bothered to help. its the retra relay ka32 is the part number, just thought I would throw it out there just in case anyone else has the same issue
Old Dec 17, 2009 | 08:21 PM
era1oner's Avatar
thanks mine just took a **** on me while drivivng at night
Old Dec 21, 2009 | 12:05 AM
kalerx7's Avatar
man ive got the same problem...but i have the so called froggy headlights, the angeleyes goes on but nothing of the headlight itsself. could it be the lightswitch??
Old Dec 21, 2009 | 04:08 PM
era1oner's Avatar
not sure if you fixed your issues with the lights, but umm i just re-tighten my grounds mainly the one thats on the fire wall to the mainfold and that solved my issue.... luck i guess.
Old Dec 21, 2009 | 04:11 PM
gracer7-rx7's Avatar
needs more track time
Your explanation is confusing. Try restating the problem
Old Dec 30, 2009 | 05:35 AM
Gary Foreman's Avatar
Gary Foreman
Gary Foreman
Hello I have just joined but have been an owner of an RX7 gen II for ten years I have restored it to a good condition but have now got a problem with the headlights and was hoping that someone could help.
The problem is the lights were working fine but one night on way home they went out, so just had side lights. Now I cant get lights to go down and the relay under the glove box is buzzing i have sourced another relay but it is still buzzing please can any one help many thanks Gary Foreman
Old Dec 30, 2009 | 12:37 PM
RTRx7's Avatar
Rammer Jammer
Gary Foreman
Generally, we try to start our own threads instead of using others for our problems.
My guess is the relay is bad, so you'll need to install a new one.
Jutta_J
Mar 25, 2017 11:24 PM
fastrx7man
33
Sep 2, 2015 09:42 PM
