Sponsored by: CARiD
problematic =(
Old Jun 18, 2009 | 03:15 AM
hairyarm's Avatar
Exclamation problematic =(
1. everything on the cluster gauge works except for the speedometer...
2. interior light dims when i accelerate...
3. i can shift gear without my clutch...???
4. my car doesnt idle like an rotary engine, infact it doesnt idle at all
5. when i shift to 5th gear i can hear a strange noise....
6. my clock is not working.
7. my break light works fine but the backup light does not work...
8. when i turn on the ac i hear air blowing but it not coming out of the vent
and it isnt cold.
9. i have an exhaust leak some where...
please give me as much information as possible on any of these problems
thanks !
Old Jun 18, 2009 | 11:07 AM
farberio's Avatar
NASA-MW ST4
1: Your speedo cable connects to the trans. Inspect it, then follow steps of FSM to fix.
2: ???
3: Normal if you rev match or the car is off.
4: Probably an massive air or vacuum leak.
5: My 86 in fifth would resonate and rattle the tape player buttons?
6: Probably shitty solder joints, or replace with a known working one.
7: The reverse gear sensor is in the trans, it has two wires coming down from it. Make sure they are connected. Some people don't reconnect them when the trans is swapped.
8: Where is the air going too? Your A/C may need a recharge as well
9: Find leak, replace part.
Coochas
44
Nov 5, 2019 11:08 PM
Megaton
May 27, 2007 12:30 AM
DVSseven
15
Sep 19, 2005 04:42 PM
