Tein rebuild
Old Jun 14, 2009 | 02:17 AM
incubuseva's Avatar
Boost knob
Tein rebuild
Anyone know where I can get my tein HE's rebuilt at? They're leaking
Old Jun 14, 2009 | 11:23 AM
Seth W's Avatar
Manlaw hater
send them to tein, they rebuilt my HA's in about a week and a half. They are a little pricey to rebuild but still cheaper then getting new ones.
Old Jun 14, 2009 | 11:45 AM
incubuseva's Avatar
Boost knob
How bad is pricey?
Old Jun 14, 2009 | 11:51 AM
jenkin's Avatar
tinea incognito
google is (or could be) your friend:
may 2008 (from that car company that makes lawn mowers forum)
Listed below is the prices for the overhaul fee and re-valve services. Also, you can upgrade your spring rate to what ever you want. Listed below is the stock spring rates for the Tein Type HA for the BB6. The MSRP cost for the springs is $50.00 per spring. If you have more please feel free to contact us. Thank you for your interest in Tein High Performance
Suspension.
Tein Type HA
Part number: DSH58-K1SS2
Front spring rate: 12kgf/mm or 671 lbs/in
Rear spring rate: 8kgf/mm or 447 lbs/in
Below is the basic breakdown of our services.
Basic/Super Street/HA/HR/NA/NR
Overhaul: $75.00 per shock
Overhaul with damper force change: $100.00 per shock
Flex/HE
Overhaul: $100.00 per shock
HG
Overhaul: $150.00 per shock
Overhaul with damper force change: $150.00 per shock
CS
Overhaul (standard): $150.00 per shock
Overhaul (inverted): $160.00 per shock
Overhaul with damper force change: $160.00 per shock
RA
RE
Overhaul (inverted): $220.00 per shock
Overhaul with damper force change (standard): $150.00 per shock
Overhaul with damper force change (inverted): $220.00 per shock
RS
Overhaul (standard): $160.00 per shock
Overhaul (inverted): $230.00 per shock
Overhaul with damper force change (standard): $160.00 per shock
Overhaul with damper force change (inverted): $230.00 per shock
HT
N1
Overhaul (standard): $190.00 per shock
Overhaul with damper force change (standard): $190.00 per shock
Best regards,
Sales
Staff @ TEIN USA INC.
9798 Firestone Blvd.
Downey, CA 90241
Phone: (562)861-9161
Fax: (562)861-9171
www.tein.com
Old Jun 14, 2009 | 12:09 PM
incubuseva's Avatar
Boost knob
Thanks. I tried looking on their site but no luck. $100 per isn't so bad.
Old Jun 14, 2009 | 05:28 PM
Seth W's Avatar
Manlaw hater
all said and done it was $750? just give them a ring, they are very helpful are usually take less than a day to reply via e-mail
Vartok
16
Oct 8, 2015 04:49 PM
