Weird missfire
Old Jun 2, 2009 | 09:40 PM
RYSO's Avatar
Weird missfire
Hey guys,
I'm trying to help a friend out, I searched but didn't find anything usefull.
The car is a 1994, S6, JDM with street port, stock ecu, stock 550cc primaries, 850cc Bosch type top feed secondaries with resistors, Walbro, Aeromotive Fpr, Fmic, 7 & 9 NGK sparkplugs, boost at 0.5bar.
The problem is that it miss fires at 5000-5500rpm's mostly when engine reached operating temperature.
I replaces coilpacks, sparkplug wires, sparkplugs, Map sensor, re-adjusted TPS, new fuel filter, even attached a fuel press gauge on the windshield and went for a drive, still no succes.... i tried to pull error codes but it won't.
Any input will be appreciated!
RYSO.
Old Jun 3, 2009 | 06:24 AM
Wo:Deep's Avatar
DAMN!Nice
look at the grounding-connection on the back of the UIM, where you would mount an engine damper.
there is the grounding wire from the engine/ECU-wiring connected with the short 7" wire to the chassis.
Look if the skrew is tight enough..
or look for any other grounding-spot on the car.
I had the same problem.
felt like a fuel-cut... it was only this connection between those two wires.
the vibrations of my engine-damper loosened the wkrew and so the two wires had no perfect connection.
after refastening the skrew everything was perfect!!
look: here you can see the grouding wire to the chassis. on the upper right of the picture you can see the mount (has a yellow dot on it!)
bigger overview:
Old Jun 3, 2009 | 06:56 AM
RYSO's Avatar
Thank you for your reply.
The ground wires you refer to is mounted and tightened!
I have added 1 thick, soldered ground cable (from battery to engine) and also a thinner one from chassis to coil bracket. It still has all other OEM ground cables.
It mostly does it when motor reaches its operating temperature.
* Note : I also noticed there is no oxygen sensor, they installed a wideband 02 in place of the OEM 02 sensor. Could this be a problem?
RYSO.
Old Jun 3, 2009 | 11:54 PM
baggedoutmazda's Avatar
Greasy bastards..
try replacing coil pack wiring harness i've read these are a common failed part. i replaced mine, it was fairly cheap from dealer.
LongDuck
Oct 7, 2015 08:12 PM
JoesFC
Oct 5, 2015 08:10 AM
Devon Murray
Sep 26, 2015 08:15 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
