afternarket ecu suggestions
Old May 29, 2009 | 02:47 AM
AchillesGr's Avatar
hi,
i am thinking to change the ecu on my car but i know nothing about the brands on the market.
can anyone please suggest one?
how dificult is to programe one? can i do it easy with a laptop?
thanks!!!
Old May 29, 2009 | 02:52 AM
amunoz3's Avatar
most common used ecu for the 3rd gen is a power fc, and yes it can be tuned using a laptop (only recommended if you know what your doing). Its whats used on my car and my local tuners know it very well.
Old May 29, 2009 | 06:52 AM
Sgtblue's Avatar
Urban Combat Vet
Arrow
Agreed.
-----> https://www.rx7club.com/power-fc-forum-47/new-version-powerfc-faq-573647/
Old May 29, 2009 | 11:01 AM
AchillesGr's Avatar
is there any software for power fc? i am trying to understand what i am going to deal with.
any comments about aem management?
thanks!
Old May 29, 2009 | 11:24 AM
Sgtblue's Avatar
Urban Combat Vet
The Apex'i PFC will come new with a base map. Two options....a "Commander" that you can monitor all sensors, Inj. duty-cycle, temps, boost etc. and make some changes. And with the optional "Datalogit", you can make major changes to the maps, but a professional is highly recommended.
Old May 29, 2009 | 12:04 PM
gracer7-rx7's Avatar
needs more track time
thanks!
The general consensus is stay away from AEM for the FD.
You have a few options depending on your overall goals and level of modifications.
There are some piggyback ECUs that work very well for a given set of mods - Pettit, RX7.com and possibly others from the UK or Australia or Japan that we never got here in the US.
Then there are standalone ECUS such as the Power FC (aka PFC), Haltech etc. All of these can be programed to fit whatever mods you want to add to your car. The benefit of the PFC is that it plugs into the stock engine harness. Some ECUs have base maps that work for a typical setup. The PFC has a base map for a car close to stock mods. All standalone ECUs require the knowledge to tune the timing and fuel for your given setup. If you don't have that knowledge, learning can be time consuming and expensive if you make a mistake. If you are going to have someone else tune the car, then they NEED to have experience with that ECU AND they need to understand how the rotary works so that they don't blow the engine using the same tuning approach applied to piston engines.
Old May 29, 2009 | 12:17 PM
AchillesGr's Avatar
hi guys,
thank you all for the help.
the pfc unit seems interesting.
my questions for that unit are:
can this unit drive the omp?
aws?
i heard some problems with the ac.
thanks!
Old May 29, 2009 | 01:28 PM
hi guys,
aws?
Yes and Yes
Go here:
and read the FAQ thread.
Old May 29, 2009 | 01:48 PM
fdfreak's Avatar
agreed, I love the PFC!
Old May 29, 2009 | 02:07 PM
AchillesGr's Avatar
ok guys,
many thanks!!
i will go for a pfc. this time i have another problem :
will the pfc will be ready to work as i receive it?i saw that there is a map already but i assume that this map will be for the stock sequential twin setup. will this work? if its setup is for twin then it will be like the stock ecu.still having trouble?
can i order the pfc with a single turbo mode ?
what can i do?
find a map for pfc? where?
my problem is that at my area there is none to setup the pfc . i must do it myself with your help
is it so dificult?
i have the stock injections and fuel system. is it a problem too?i am not going for 500ps.
i changed the intercooler and now i am fiting an areomotive fuel pressure regulator .
the air pump is removed
egr is removed
double throtle is removed
thats all i have done so far.
thanks again for your suport
Old May 29, 2009 | 02:33 PM
What are your mods? The base map is OK for use with sequential twins and some air flow mods.
For single turbo, the tune (timing, fuel etc) needs to match the air flow needs of the motor and turbo and intercooler, exhaust etc. Different turbo setup, different exhaust setups will require different tuning of the fuel and timing to match the air flow. A map from another single turbo might be close. It requires knowledge to safely tune/adjust the ECU to work with the air flow needs of the motor. Some people are capable of learning that on their own. Some are not. Some think they are.
Some people say that a good approach is to use the ECU for which you have a local tuner if you need a programmable ECU to fit the custom needs of your motor.
Old May 29, 2009 | 02:42 PM
FDSeoul's Avatar
Corea FD
find a local tuner who works with rotary and ask what ecu he knows and tunes. The ecu is only good as the tuner you can get to and have easy access to. other wise, Yes Apex-i PFC is a great stand alone. IMO
Old May 29, 2009 | 02:48 PM
Sgtblue's Avatar
Urban Combat Vet
ok guys,
many thanks!!
If you buy the PFC new, while not ideal, the base map that comes with it should be suitable for most aftermarket intercoolers, intake and exhaust. Professional tuning is safer and recommended.
can i order the pfc with a single turbo mode ?what can i do?find a map for pfc? where?
No. But if you go the Apex'i PFC section of this forum, you may find some help with maps for a particular single turbo set-up.
is it so dificult?
For basic installation and to get your car up and running properly with the base map, go to the link I provided earlier (from DaleClark)
No, stock injectors should be sufficient for mild mods like you mentioned as long as you keep it at stock boost levels (.7 bar or 10 psi). IMO, there is no need for the aftermarket regulator on the stock fuel system....unless maybe your able to delete the Fuel Pulsation Dampner as a result.
egr is removed
I think you indicated you still have AWS. Personally I would recommend you delete that as well. There will be no issues with the PFC for deleting any of those.
Old May 29, 2009 | 03:21 PM
AchillesGr's Avatar
Jim , thanks
the regulator is a gift for a friend . i have it so i will fit it. also i read ate the aeromotives instructions that the pulsation dumper is no need anymore . do you suggest to remove it or leave it? i heard stories that it broke and the car cought fire.
the injectors will be my next step. for now i am thinking the ecu upgrade .
i want to leave the boost at the factory 10psi max because i do not have any ceramics apex seals.am i right? can i change the injectors and increase the boost without ceramics?
thanks!!!
Old May 29, 2009 | 03:42 PM
Its not the ceramic apex seals that limit how much boost is safe to run. It is injector capacity and duty cycle. The stock fuel injectors have enough fuel for somewhere between 12-13 PSI (I forget exactly). You generally want injector duty cycle under about 86%.
Once you have an ECU like the PFC, you can go with larger secondary injectors and change the settings in the PFC to manage the larger injectors. Lots of people get the secondaries bored out to 1200 or 1300cc by RC Engineering.
Many aftermarket FPR incorporate their own dampeners so the stock FPD is rendered unnecessary. The FPD can leak over time (probably due to heat exposure) and can cause fire if not fixed.
younG_Gunner
Sep 9, 2015 08:26 PM
mulcryant
Sep 9, 2015 05:24 PM
nkuhajda
Sep 7, 2015 04:07 PM
