Window help
Old May 27, 2009 | 09:37 PM
Petar_rx7's Avatar
Window help
Well, i got 2 doors with no interior lining or anything to it, its just the shell with the windows but 1 window is stuck up and it wont go down and the screws for the little pump at the bottom of the door are gone and its sitting inside nothing supporting it, i dont want to force it down cause that might break the glass or something else, basically i cant get the windows to go down,
And on the second door the window is completely out of the rubber padding and it is inside the door alltogether, how can i safely get that out without breaking it
Old May 27, 2009 | 09:55 PM
mar3's Avatar
Administrator
I'm assuming this is the '88 RX-7? Can any 2ndgen guru's help this guy out? I'm a 1stgen guy myself and I don't want to mislead him...
Mario III
Old May 28, 2009 | 02:48 AM
Petar_rx7's Avatar
Yeah its a 88 Rx7 and i need help badly with this i do not want to break the windows
Old May 28, 2009 | 09:16 PM
mar3's Avatar
Administrator
Anybody? Anybody? man, the 2ndgen crowd is so slow to respond...
Old May 29, 2009 | 01:03 AM
Petar_rx7's Avatar
Please? K ill explain it again, the windows, were not rolled down, 1 is stuck upward and will not roll down , the second, is inside the actual door itself sitting with nothing supporting it, like its completely off the rubber padding/rails how can i get it out without braking the window and how can i roll down the window i only have the shell of the door
Old Sep 5, 2009 | 03:10 PM
udmmessiah's Avatar
man... im looking for the answer my self.. i have a 2nd gen... both power windows were doing great. now my driver side is stuck down and the passanger wont go up or down. is it the fuse that we are having problems with ?
Old Sep 5, 2009 | 04:18 PM
VegasG8R's Avatar
Can you pull off the interior door panels and after lubing the crap out of everything, (let the stuff penetrate) try to coax the windows into operation?
Just don't put pressure on the glass... as you mentioned. Be easy, patience grasshopper, patience....
Old Sep 7, 2009 | 10:18 PM
R0tary P0wer's Avatar
Extreme Rotary Works
could the motor be sticking? have you checked the fuse?
DocHoliday89
Power FC Forum
11
Feb 18, 2018 01:35 AM
turbojeff
Oct 5, 2015 10:50 AM
