Little black cylinder carbon can?
Old May 27, 2009 | 04:21 PM
InteliousYelwo's Avatar
Got new fuel pump... Had no Gas to Carb...
and now gas just starts leaking out of the bottom of the can.
Is it a carbon canister? How do i fix it?
Or where can i get one?
1983 rexy
Old May 27, 2009 | 06:19 PM
Crit's Avatar
No distributor? No thanks
Sounds like you swapped your lines. You've got three fuel-related hardlines at the firewall - fuel supply, fuel return, and gas tank vent to the charcoal canister. You've plumbed your fuel supply to the charcoal canister. Check your lines and you should be okay.
Old Jun 28, 2009 | 06:00 PM
Do you know where i could find a diagram for the fuel system? Or can any one tell me which line i need to get gas to...
1983 Sexy Rexy
Old Jun 29, 2009 | 07:21 AM
Kentetsu's Avatar
www.sterlingmetalworks.com
Old Jul 1, 2009 | 06:04 AM
mazdaverx713b's Avatar
Have RX-7, will restore
remember, all the charcoal canister does is trap excess fuel vapors
