94 rx7 v-mount set up
Old May 23, 2009 | 02:21 PM
Dirrty's Avatar
I have my 94 13b and i installed a v-mount set up and i am wondering what im supposed to do with the 2 stock blow-off valves? and which vacuum hose i plug off and use? ive tried switching vacuum lines and just unplugging the bovs but then my secondary fuel rail never kicks in? does anybody know what i can do or where i can buy a good intake?
Old May 23, 2009 | 07:31 PM
IRPerformance's Avatar
Sponsor
Does your new intercooler have a blow off valve?
Old May 23, 2009 | 11:24 PM
Dirrty's Avatar
yes its located on the inlet pipe to the intercooler
Old May 24, 2009 | 09:38 AM
Sponsor
If you are running the sequential turbos, you will need to keep the charge relief valve (back one) The other one that is towards the middle of the y-pipe you can remove and cap off. Just run a vacuum hose to your new blow off valve. You can source vacuum anywhere off the intake manifold by try to keep the hose as short as possible. This has nothing to do with the fuel rail. Where in NY are you? If you want bring the car by my shop.
autoxer
21
May 22, 2019 04:07 PM
mustanghammer
Race Car Tech
28
Nov 22, 2015 07:10 AM
Wolf_
Aug 11, 2015 04:23 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
