help
Old May 15, 2009 | 08:43 AM
delsisol's Avatar
Your ****'s Weak
Unhappy help
hey guys in mew to this site and from tampa.... this is my first rotary, and just blew the motor with a supercharger.... i need help with finding a new one and info on putting a 20b in my vert.. also info on which motor would be better in it thanks
Old May 15, 2009 | 10:24 AM
Aaron Cake's Avatar
Engine, Not Motor
Uh, your question is a bit inconsistent. It sounds a bit made up.
If you can fabricate a supercharger setup for your 'Vert, then certainly you should already know what would be involved in installing a 20B. Or at least you are capable of checking the 20B forum for this information.
Then you go on to ask what is the best engine. I thought you wanted a 20B?
I'm not trying to be a jerk but you need to clarify exactly what you are trying to do. It really helps if you put the effort into making complete sentences with actual punctuation as it will get your ideas across far more easily.
Old May 15, 2009 | 08:35 PM
delsisol's Avatar
Your ****'s Weak
sorry. i didn't fab the supercharger onto my car it was a kit. i dont know much about rotary's and i need a motor for my rx. i've herd 20b's are good but are hard to put in. i was just wondering on how hard and how much extra cash they cost to put in.. if there really a pain in the bum to put in, which motor should i go with?
Old May 15, 2009 | 08:40 PM
delsisol's Avatar
Your ****'s Weak
here is a pic of the kit on the car
http://viewmorepics.myspace.com/inde...ageID=59357391
and what the supercharger looks like now.
http://viewmorepics.myspace.com/inde...ageID=59357527
Old May 15, 2009 | 09:30 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Your profile is private, so no one can see any of those pictures.
In any case, trying to swap in a 20B is likely going to be a 10-15k adventure. You'd probably be best going with a turbo swap from the same series as your car. More information available in the FAQ.
