e-brake light...
Old May 14, 2009 | 12:26 PM
SL1CK's Avatar
MA e-brake light...
Doesn't turn off even when the my e-brake is completely all the way down. Whats the deal?
Old May 15, 2009 | 10:52 AM
Aaron Cake's Avatar
Engine, Not Motor
Check your brake fluid level.
Old May 15, 2009 | 02:13 PM
IFRYRCE's Avatar
E brake adjustment, take off your center console.
Old May 15, 2009 | 02:21 PM
g14novak's Avatar
The Doctor
Uh, not really. Theirs 1 screw on the side of the e-brake handle you undo and the thing pretty much falls apart.
But +1 on checking your brake fluid level. My light kept staying on and this ended up being it.
Old May 15, 2009 | 10:58 PM
rxtasy3's Avatar
the switch is stuck. mine does that sometimes. just haven't taken the time to check mine out. works like the pin switch for the interior light when the door opens.
Old May 16, 2009 | 10:57 AM
IFRYRCE's Avatar
Um, not really. There's THREE screws, and also a long nut on the actual cable. The nut is the adjustment.
http://s199.photobucket.com/albums/a...ildDay1013.jpg
Bam, three bolt holes. Ty.
My bet is still that or a stuck button.
Old May 16, 2009 | 01:21 PM
Aaron Cake's Avatar
Engine, Not Motor
There is ONE adjustment screw on the 2nd gen parking brake lever. There is ONE screw that holds on the trim...
