93 singal turbo starting problem
Old May 11, 2009 | 02:29 PM
Sdoan's Avatar
MN 93 singal turbo starting problem
I bought a 93 rx7 about 3 weeks ago as a non running car the car it has a reman motor with about 2k miles on it he also has a power fc hks twin power and gt35r turbo on it with 850cc primary injectors with 1500cc secondary injectors when i first got the car it was not getting fuel pressure and it was only sparking from the leading spark plugs but both the trailing did not start. i went out and bought a new fuel pump then now i have fuel pressure then i took the ignition coils out and saw one of the prongs inside trailing 2 was bent so that fixed my problem in for one of my trailing plugs but i still cant figure out why trailing 1 dose not fire but when i got to start my car now it just cranks and sometimes back fire. im out of ideas any help would be great thanks.
the last thing that the guy did b4 the car did not start anymore was he messed with the idle control valve but ive been messing with that forever and there has not been much change.
also if you live in the twin city area and thing you could fix this i would gladly pay you. thank you
Old May 12, 2009 | 09:37 PM
NOPISTONS?'s Avatar
It's hard to say why one of your coils doesent fire, hate to just blame it on the coil. Do you know if they are factory? Some people change to T2 coils and they look plain, but I'm not sure if they have to change the plug, their could be a bad splice if so. I would start by makeing sure your plugs are clean and very dry, charge the battry good and try again. If it's backfiering you have some fire, checked the fiering order right?
Old May 12, 2009 | 11:29 PM
Sdoan's Avatar
i know the coil is not bad because when i plug the trailing 2 plug into the trailing 1 coil then theres spark theres just no signal in the trailing 1 plug. what could cause the wire not to send the signal?
Old May 16, 2009 | 08:31 PM
NOPISTONS?'s Avatar
Sorry for not getting back, I havent had my computer. Does one of the pins in the plug have power with the key on? Do you have a noid light for checking injectors, did you get the cars origanal computer with it? If your crank sensor failed you would not have injector pulse, if your computer failed it should start with the old one. If all you lost was one coil I would look for a repair in the harness or a bad, loose, or missing ground. With the PFC you have to cut wiers next to the computer, I had cut the first 2 wrong and had to solder them back together. Look for stuff like this.
Kyo
Apr 13, 2019 09:24 AM
sherff
Feb 24, 2019 12:09 PM
alphawolff
Nov 17, 2015 05:57 PM
