need help 2nd gen Ive had 11yrs n its been a headache
Old May 1, 2009 | 06:33 PM
savaughn's Avatar
I can't find an aftermarket pulley set for the fc can any1 help b4 I blow my motor that I just put in. Its slipping on the pulleys at 4000rpm I'm changing belts every 2weeks can sum1 help so I can boost???
Old May 2, 2009 | 08:18 PM
misterstyx69's Avatar
Retired Moderator, RIP
why not change belts first?..RacingBeat has underdrive pulleys.
Old May 2, 2009 | 09:34 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Racing beat double pulley or put the air pump back on.
Old May 2, 2009 | 09:35 PM
farberio's Avatar
NASA-MW ST4
You went 11 years changing your belts every two weeks??
That's dedication!!
Old May 3, 2009 | 11:07 AM
savaughn's Avatar
I'm gonna call racing beat first thing n the morn thanks bro! I have not been changn belts every 2 weeks 4 11yrs lol but I've been buildn the car that long n been having nothing but problems like how can u crack the back plate on the block can any1 explain that
Old May 3, 2009 | 11:24 AM
farberio's Avatar
NASA-MW ST4
Sure, drop it on a hard surface, worn out, too much boost on the old non-thick casting plates, Really bad detonation.
Old May 3, 2009 | 12:12 PM
savaughn's Avatar
What would cause bad detonation it happend twice on the dyno?
Old May 3, 2009 | 06:53 PM
farberio's Avatar
NASA-MW ST4
Bad tune, bad gas, low octane gas, bad fuel delivery, crappy spark, intake charge too hot. There is like a million reasons.
If it happened on the dyno twice I am guessing it was being tuned? Sounds like you need to find a different tuner.
Old May 4, 2009 | 12:38 PM
savaughn's Avatar
Yea it was being tuned I thought maybe it was the tuner also so I was gonna shop around 4 sum1 else! But I called racing beat they don't hav what I'm lookn 4 ! I'm lookn 4 the type that's **** on the fd but custom made 4 the fc like the glimmer 1s I can't seem 2 find racing beat don't offer the water pump pulley and I nd all of them cause like an ******* I had all of the ones I hav powder coated that's y there slippn the set I'm tryn 2 get **** with 3pulleys n a belt 1main crank 1water pump 1alt with a serpentine belt sum1 told me 2 check out mazda factory racing (mfr) but I heard they went out of business n I can't seem 2 find nothing on the web !!!
Old May 4, 2009 | 05:49 PM
farberio's Avatar
NASA-MW ST4
The only belts for serpentine are the gilmer ones, and they are found at tweak it.
And, if you can, please use better English next time, I am at my limits in understanding you. Especially when you are looking for things that **** on the fd.
Old May 5, 2009 | 06:46 PM
savaughn's Avatar
Thanks 4 your help. I ordered it 2day and sorry 4 disrespecting the fd!!
demetlaw
Oct 2, 2015 06:22 PM
