water jacket
Old Apr 30, 2009 | 11:17 PM
thejallenator's Avatar
water jacket
how hard would it be to repair this? on a na s4 motor? came across a motor on craigslist and its almost free for the motor but the water jacket is said to be damaged. i was just htinking about pickin this up and jumping into one head first so i can get a good feel for how everything inside works... is it fixable without a rebuild?
Old May 1, 2009 | 09:31 AM
Kentetsu's Avatar
If the problem is a bad coolant seal then I've got a fix for you. If the engine actually has a crack in the metal somewhere then that's a different story...
Logan Reinisch
44
Sep 17, 2018 12:20 PM
