When my car starts it's REALLY Loud.
Old May 29, 2002 | 01:05 AM
My friend installed a Denzo Blow off valve and whenever I start the car it's really loud, like sucking sounds.. I can't explain how Loud but is Loud. The car normally gets 2-3 rpms when i start it, could it be loose or is that normal?
Old May 29, 2002 | 01:19 AM
mightyslash's Avatar
Will Work for Ferrari
2-3k rpm is normal on start up. The BOV shouldnt have anything to do with your car being loud when you start it because all it does is release the boost pressure.
Old May 29, 2002 | 09:50 AM
djantlive's Avatar
FDs have the accelerated warm up system (AWS) that kicks the rpm to 3k when the engine is cold upon startup. So, it's pretty loud. You can defeat the AWS by starting in gear or just tapping the gas a little.
If your car is still loud and there is a sucking sound, check all the intake hoses and airbox. Maybe one of them isn't fitting perfectly and is leaking.
Old May 29, 2002 | 11:08 AM
Pressurized's Avatar
It sounds normal to me. When I had my stock BOV vented before I disabled the AWS system, there would be a huge surge of air rushing out of it, I would call it more of a blowing sound than a sucking one...almost like a hiss.
Kyo
Apr 13, 2019 09:24 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
gtcd
30
Aug 19, 2015 02:44 AM
torky007
Aug 17, 2015 05:14 PM
