FMIC downsides
Old May 28, 2002 | 11:28 PM
lovemyseven's Avatar
What funny smell?
FMIC downsides
I bought a FMIC and installed it, I have heard of different downsides to FMIC large IC's like heat soak, and pressure drop. What do these mean?
thanks
Old May 28, 2002 | 11:51 PM
93TTRX7's Avatar
your radiator doesn't get as good air flow through it...so the car runs hotter that's what i've heard. If I were you I'd get aftermarket fans and run them all day
Old May 28, 2002 | 11:55 PM
What funny smell?
why do you need aftermarket fans, why not just wire up a switch to the stock fans, and turn them on and off at will?
Old May 28, 2002 | 11:56 PM
Cetchup's Avatar
The Cursed FD
FMICs dont get heat soaked generally because they are directly placed in the air stream.
SMIC's get heat soaked (usually smaller ones like GReddy or Blitz are prone to this. I have heard good things about M2s SMICs tho) because they are sitting in the engine bay along with all that heat that your engine puts out. The heat "soaks" your IC making it sort of useless. But that usually occurs in stop and go traffic...
There is a HUGE thread on this. Go ahead and search for it. The button is in the top right corner. Just type in FMIC and SMIC...GL!
Old May 29, 2002 | 01:35 AM
RedR1's Avatar
Out of order
as cetchup said, theres an overly huge thread on the topic, and it goes very in depth, but to sum it up in a few brief statements:
FMIC blocks airflow to radiator, would work great with vented hood to help circulate air in engine bay, road debris can fauxx up yer fmic, etc.
theres lots of info in that thread
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
