help: have fuel,spark,air and great compresson but will not run!!!
Old Apr 28, 2009 | 09:40 PM
jason duncan's Avatar
deep7
Angry help: have fuel,spark,air and great compresson but will not run!!!
I have a third gen that has a few minor modicications like the power fc and commander, front mount, exhaust etc.. The problem is that with all of this the car was running when i got it but it would not boost!! found the turbos were bad. Replaced the turbos and now the car will not run!! Compression is great, about 110 per rotor, fuel pump is working and injectors are firing, plugs are brand new and the engine is getting spark!!! Any help out there on this please feel free!!!! thnx....
Old Apr 29, 2009 | 05:54 PM
newvalor's Avatar
Did you remove any sensors or disconnect anything while removing/installing the new turbo's?? you may have hit something or forgot to reconnect after the work.
alphawolff
Nov 17, 2015 05:57 PM
Wolf_
Aug 11, 2015 04:23 PM
