lsd
Old Apr 28, 2009 | 03:18 PM
thejallenator's Avatar
lsd
kind of a stupid question but was curious.
ive come across this many times now while searching craigslist and was kinda curious about it. is this just like a replacement for the gears in a lsd tranny or what? idk not really sure what it is
http://portland.craigslist.org/clc/pts/1141929664.html
Old Apr 29, 2009 | 03:55 PM
possuman's Avatar
A differential is the rear axel that changes the engine/driveshaft rotation to the correct direction to turn the wheels. This part will apparently replace the center section of some Rx-7 differential with a limited slip unit that sends power to both wheels instead of just one. Some Rx-7s came with a lsd stock. Some did not. It would not fit all Rx-7's. You would have to check with the seller to find out what specific application he bought it for. Some lsd's can be found new for near that same price.
Josh83rx7
Oct 2, 2015 07:13 AM
Josh83rx7
Sep 24, 2015 11:47 AM
