Guages
Old Apr 16, 2009 | 03:59 PM
Wiggles.'s Avatar
Guages
On an FD which additional gauges would you guys add?
I know a decent boost gauge is needed, but what order of importance would you put things like oil pressure, oil temp, water temp, F:A mix gauges in.
thanks for your input
Old Apr 16, 2009 | 06:04 PM
IanS's Avatar
Ricer
If you want the ones that are most important go with oil press, oil temp, water temp. As long as you are tuned good you shouldnt need Air/Fuel although it wouldnt hurt. Basically everything you listed is on track with what you need.
Old Apr 16, 2009 | 08:15 PM
dgeesaman's Avatar
I would keep IanS's list but put the water temp gauge first.
Only do the A/F gauge if you're going to use a wideband sensor.
Old Apr 17, 2009 | 09:51 AM
Wiggles.'s Avatar
Thanks guys
all just thinking for the the future... but i like to do my research first!
Old Apr 17, 2009 | 10:24 AM
another7driver's Avatar
Listener
Personally, I'd go with a 2 gauge pod. One for a dedicated boost controller, and an electronic gauge with sensors for everything mentioned. Much cleaner and if you can afford to maintain a FD, price shouldn't be a problem.
gabescanlon
Sep 5, 2015 12:09 AM
