Sponsored by: CARiD
Power Steeirng Problem
Old May 27, 2002 | 06:26 PM
Question Power Steeirng Problem
Hi Everyone,
I bumped into a problem with the R1’s power steering system during an autocross event. After a quick succession of corners, I ended up “pumping the pump”. Steering effort increased significantly for a few seconds. Can you guys let me know if you had any similar experiences? Does this sound like an inherent design issue or do I have a mechanical problem? Note that the PS cooling lines were not installed.
If it’s the former, I want to try and increase the pump’s flow and drop the output pressure (to decrease the power assist). For this I would have to muck with the flow control valve spring and maybe the pulley diameter, I think. This would change the flow, but what about the pressure? I think the steering is over assisted. Does the RX-7 have a torsion rod controlled spool valve? The manual only talks about a pinion shaft.
Any input is appreciated.
Old May 29, 2002 | 12:08 AM
Wargasm's Avatar
Weird Cat Man
Check out the pictures here for the answer to your pinion question.
http://www.zeroglabs.com/rx7/steering.htm
Brian
Queppa
Nov 18, 2024 03:47 AM
distr0
Megasquirt Forum
48
Mar 18, 2022 06:17 PM
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
