n/a and turbo clutch
Old Apr 9, 2009 | 01:54 PM
RotaryWonder's Avatar
Newbie
MI n/a and turbo clutch
ok newb here, i have a 86 gxl im swaping a streetport 13b into, thinkin its time for a new clutch and bearings, are the turbo and n/a's clutches and pressure plates and bearings diff?
Old Apr 10, 2009 | 09:12 AM
farberio's Avatar
NASA-MW ST4
yes they are different, you will need to run an N/A clutch.
Old Apr 10, 2009 | 09:38 AM
Aaron Cake's Avatar
Engine, Not Motor
The rule is that the clutch, flywheel, starter and slave cylinder needs to match the transmission. So you need NA parts.
Old Apr 10, 2009 | 09:49 AM
Kentetsu's Avatar
Where in Michigan?
Old Apr 11, 2009 | 12:04 AM
Newbie
MI thanks
thanks i wasnt sure but knew they were most likley diff, i live in Portage kalamazoo county, rx7s are getting bigger around here we have a car club called kzoorice if you ever want to check it out www.kzoorice.com (not sure if thats against the rules sorry if it is).
hotshot2014
Jul 18, 2017 02:30 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
