Shreeking sound!
Old May 26, 2002 | 10:22 PM
mwpayne's Avatar
Admitted 'rexaholic'
Shreeking sound!
At Hi RPM's on my 85, there is a very loud shreek-like sound coming from the motor area. Thought it was a belt, replace AC and alternator, no change.
What the heck is this?
Thanks!
Old May 27, 2002 | 06:13 AM
DONNA's Avatar
sounds like bearings going out on something, had the problem with my zx, was the belt tension pulley, finally it siezed up and threw the belt off, get a two foot piece of garden hose and put one end to your ear and the other end to spots in the engine area,works like a stethascope, good luck,,,,,
Old May 27, 2002 | 09:48 AM
damon's Avatar
have you removed the smog pump or any of the other pulleys lately , it sounds like the infamous "need a two groove alternator pulley" syndrome that a lot of us have
Check out http://racingbeat.com or
http://mazdatrix.com for a new one
Old May 27, 2002 | 09:56 AM
mwpayne's Avatar
I did take the air pump off long enough to wd-40 the bolts & threads (everthing has rust on it) but it did this before and after. Guess I'm gonna have to narrow down which device is squealing. What is the advantage of the two groove alternator pulley?
Old May 27, 2002 | 10:04 AM
damon's Avatar
well if you have removed the pump or any of the other pulleys then the resistance of the belt in the groove has been reduced and the high rpm is causing the tiny belt to slip in its track , adding the double pulley adds resistance and reduces slipping
peace
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
