Just bought an 85 rx7gs
Old Mar 30, 2009 | 10:28 PM
rotarysami's Avatar
the guy i bought it from did was not able to put the carburetor back on do to an injury and it has been sitting for a few years,
the interior needs some tlc
what are your thoughts for getting it running after sitting
Old Mar 30, 2009 | 11:44 PM
blamming's Avatar
I don't think it'd be too hard. I've let my car sit for over a year and it started just fine, it may flood a little. if that happens pinch off the fuel lines, pull the spark plugs and turn it over for a bit. It should blow the fuel out the plug holes and you'll be good to go.
Old Mar 31, 2009 | 12:00 AM
trochoid's Avatar
Old Fart Young at Heart
Read through the FAQs in the 1st gen tech section. Hopefully the intake was covered during this time to prevent 'stuff' from getting into the engine. Carb will most likely need rebuilt and the entire fuel system cleaned, fluids/filters changed, etc.. The following links should help get you started.
https://www.rx7club.com/showthread.p...postid=2385473
http://foxed.ca/foxed/index.php?page=rx7manual
http://www.wankel.net/~krwright/cars/rx7/manuals.html
Old Mar 31, 2009 | 05:57 AM
xDspec's Avatar
a little atf to eat away carbon and nasties out of the motor
Old Mar 31, 2009 | 11:02 AM
Kentetsu's Avatar
Not ATF, use Seafoam instead. Rotaries love Seafoam. Drain the gas out of the tank, change the fuel filter, mount the carb, dump a couple ounces of Seafoam down the carb, put the rest in the tank with a few gallons of FRESH GAS, then start her up....
Old Mar 31, 2009 | 10:01 PM
rotarysami's Avatar
what about putting a little oil in the intake to get the seals up to par, or is that unnecessary
Old Apr 2, 2009 | 02:04 AM
trochoid's Avatar
Seafoam will do the same thing, help build compression, while also softening and removing carbon.
MikeTee55
Sep 8, 2015 08:05 PM
