Anyone use a G-Force ECU?
Old May 26, 2002 | 09:57 AM
jmo87's Avatar
I use one and it set up for "upgraded turbo" does that mean single or upgraded twins? I'm getting my motor built and peice of a seal ate the stock turbo all up, so I'm tryin to figure out if I can run a single on the g-force. Can someone help me out here? Thanks!
Old May 26, 2002 | 10:34 AM
twntrbo's Avatar
i use a g- force ecu! but i think it is only programed for upgraded twins not single. U can call g-force and they would be able to tell u for sure though. If i were going single i would use the power fc but thats just my oppinion.
Old May 26, 2002 | 11:43 AM
Want2race's Avatar
Bigger and better things
i do not believe any stock ecu should be programmed for a single... so im thinking highflow twins...
Old May 26, 2002 | 12:18 PM
jmo87's Avatar
g-force is no longer around or i would call them. i guess ill just go with upgraded twins then, thanks!
Erosangel
Sep 18, 2015 10:28 PM
Erosangel
Sep 18, 2015 04:06 PM
