Replaced fuel injectors BUT
Old Mar 29, 2009 | 11:25 AM
fcs3l0ve's Avatar
No Pistons!
Question Replaced fuel injectors BUT
there is still a really strong fuel odor and the car won't start. When I crank it sometimes it will go to start then just stop. Does anyone have any idea what the problem with this could be?
Car: 86 RX7 GXL N/A
Old Mar 29, 2009 | 03:48 PM
misterstyx69's Avatar
Retired Moderator, RIP
look up Flooded..Deflooding Procedure.
Your car is most likely Flooded.Bad.
also search:car won't start..Something along those lines...oh also check for Fuel leaks,as you just replaced injectors,and chcek all hoses and make sure the AFM is plugged in.
Old Mar 29, 2009 | 04:55 PM
Go48's Avatar
Check the plug on the AFM.
82streetracer
Aug 23, 2015 09:28 AM
86rxNa
Aug 11, 2015 11:51 AM
