How do I get atf in my engine?
Old May 25, 2002 | 04:29 PM
PalmCity RX-7's Avatar
Eager to please
I'm trying to put Atf in through the trailing plug holes, but when i pull the funnel out, all the atf runs back out. Can I put the atf in through the carb and intake manifold, or will that **** up my carb/jets?
Old May 25, 2002 | 04:36 PM
yayarx7's Avatar
Are you Nucking Futs?
How much are you trying to put in? If the rotor face is right near the plug holes only a minimal amount will fit. Try rotating the engine till the apex seal is below the leading (lower) sparkplug holes, and put the atf in the trailing (upper) plug holes. Repeat for all 3 sides of both rotors.
Old May 25, 2002 | 04:53 PM
Eager to please
I'll go out and try again, thanks
Old May 25, 2002 | 04:55 PM
yayarx7's Avatar
BTW I do not think you need more than a few tablespoons per rotor face, someone correct me if they think he needs more.
Old May 25, 2002 | 07:11 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Well first take the big jug of ATF and drink a bunch, now firmly put your mouth over the tail pipe and blow, it will get back up in there LOL Just joking...
The reason its coming out of the trailings holes is cause on the inside of the rotor housing the hole is about the size of a toothpick... Just pour it in the carb, and open the throttle. When you are done, wash it down a little with carb cleaner
Old May 25, 2002 | 09:37 PM
Eager to please
I went back and did it... I forgot to tighten the leading spark plugs and the atf was running out of those holes. I'm going to let the car sit for a week now, then drain out the excess and try to start it.
Old May 25, 2002 | 11:02 PM
Rotor13B's Avatar
Wassup!!
Damn, he said a week, lol
Old May 26, 2002 | 12:49 AM
V8kilr's Avatar
here are to threads i wrote up on the subject with pics,
i poured it straight through the carb
ATF is brewing as we speak
ATF pics are ready come see
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
