Drifference between engine and drivetrain.
Old Mar 17, 2009 | 12:07 PM
Hellemyr's Avatar
So i got a 86 rx-7 with a swapped engine. Im pretty shure its a 89-92 turbo II engine, by looking at the intercooler and water fill neck.
But how can i look at the drivetrain, suspenson and brakes to see if they are from the 86 car, or from the turbo car where the engine came from?
Old Mar 17, 2009 | 02:55 PM
Aaron Cake's Avatar
Engine, Not Motor
It doesn't really matter. There are only a few minor differences. S5 (89+) uses plastic sway bar end links and integrated ball joints. That's about the only difference.
Old Mar 17, 2009 | 03:37 PM
RotaryRocket88's Avatar
Top Down, Boost Up
For the drivetrain, a turbo transmission will have a removeable cover on the bottom, while an NA does not. And a turbo LSD rear-end will have a tag that says it is limited slip & it will have 11 "ribs" on the case (vs. 9 NA).
Th0m4s
Feb 26, 2019 02:04 AM
