Leak...:(
Old Mar 17, 2009 | 11:01 AM
xymox's Avatar
Leak...:(
okay so it seem like i am leaking something near my tranny...i just changed the lug seal but i just cant seem to figure out where it is coming from
Old Mar 17, 2009 | 03:00 PM
Aaron Cake's Avatar
Engine, Not Motor
How would we know?
Thoroughly clean the area with degreaser and make sure it is spotless. Now drive the car a short distance and then park it. Get under there an examine the area of the suspected leak. Did you find it? Using this method you should be able to pinpoint the area. Common leaks are the tranmission input seal, and output seal.
Old Mar 18, 2009 | 06:16 PM
dgeesaman's Avatar
What fluid is leaking?
If you're not sure, I suggest you take it to a mechanic for diagnosis.
Dave
Old Mar 19, 2009 | 08:26 PM
xymox's Avatar
thanks for the advice, i tried to clean out the area and look for the leak, and no results. So i think im just going to have to get it checked out and clean out my wallet lol
Old Mar 19, 2009 | 08:39 PM
88verttop's Avatar
what kind of fluid and is it towards the front or back of your transmission mine started leaking oil from the rear stationary gear so if its oil it could be that but if its a seal on the transmission it wont be that hard to tackle if you are mechanically inclined
Old Mar 20, 2009 | 01:01 PM
xymox's Avatar
its toward the rear of the the transmission. it might be the stationary gear but the only thing is that its not oil, i already had the input and output seals changed
