What does a stock 3rd gen rx7 rim weigh?
Old Mar 2, 2009 | 11:36 AM
gte's Avatar
gte
I was hoping it'd be in this thread
https://www.rx7club.com/showthread.p...t=wheel+weight
but it was not.
It looks like all are 16x8? With a 50mm offset and a 5x114.3 bolt pattern?
Also, what do the factory tire and wheel weigh together?
Thanks!
Stock Tire - 205/65R16 >Search Tires Tire 1 - 225/50R16 Tires
Section Width: 8.07 in 205 mm
Section Width: 8.85 in 225 mm
Rim Diameter: 16 in 406.4 mm
Rim Width Range: 5.5 - 7.5 in
Rim Width Range: 6 - 8.5 in
Overall Diameter: 26.49 in 672.84 mm
Overall Diameter: 24.85 in 631.19 mm
Sidewall Height: 5.24 in 133.09 mm
Sidewall Height: 4.42 in 112.26 mm
Radius: 13.24 in 336.29 mm
Radius: 12.42 in 315.46 mm
Circumference: 83.22 in 2113.7 mm
Circumference: 78.06 in 1982.7 mm
Revs per Mile: 785.2
Revs per Mile: 837.0
Actual Speed: 60 mph 100 km/h
Speedometer1: 63.9 mph 106. km/h
Speedometer Difference: - Speedometer Difference: 6.597% too fast
Old Mar 2, 2009 | 11:53 AM
gte's Avatar
gte
I found on a Toyota forum that a special version of the 3rd gen wheel weighed 13 lbs? Is this correct? If so, what does the standard version weigh?
Old Mar 2, 2009 | 01:23 PM
4CN A1R's Avatar
sleeper
there 15lbs each
Old Mar 3, 2009 | 08:52 AM
gte's Avatar
gte
Thanks!
Old Mar 3, 2009 | 02:29 PM
90FC's Avatar
Dark Side
IIRC, the 93 had the lighter wheels, and the 94+ had the heavier ones. I could be wrong though.
Old Mar 3, 2009 | 05:03 PM
Mahjik's Avatar
Mr. Links
Arrow
https://www.rx7club.com/suspension-wheels-tires-brakes-archive-112/wheel-weights-add-your-wheel-weight-if-not-listed-dont-chat-thread-87008/
mustanghammer
Race Car Tech
28
Nov 22, 2015 07:10 AM
