Microtech Will changing pulleys change my setup?
Old Feb 24, 2009 | 03:38 PM
Laz93RX7's Avatar
All Hail the Magic Conch!
Question Will changing pulleys change my setup?
will changing to lighter pulleys change my tune, I'm asking if I change to unorthodox main, alt, water, and power steering aluminum pulleys will it mess up my tune or not?
Old Feb 24, 2009 | 05:01 PM
rx72c's Avatar
Top Answer: 1
It shouldnt affect your tune.
Just make sure the main pulley has proper timing marks on it.
Old Feb 24, 2009 | 09:40 PM
Trots*88TII-AE*'s Avatar
4th string e-armchair QB
Yeah, make sure it is guaranteed on time before swapping them out, and see if they line up. Many (most?) aftermarket pulleys for 13B's have improper timing marks.
Old Mar 10, 2009 | 07:44 PM
BurntOrangeT2's Avatar
No phonebook but OG calls
i thought the timming was controlled by the CAS? If the main pulley is what does what do the marks look like ive never looked
Old Mar 11, 2009 | 04:54 PM
rx72c's Avatar
Top Answer: 1
Youll see two notches.
Blue and orange. But ive seen different colours as well.
Old Mar 11, 2009 | 05:55 PM
BASTARD's Avatar
The FD has a trigger wheel on the front pulley... if the triggers are not in the same spot as the one you are removing then the timing could be effected
The FC uses a CAS similar to a distributor which will have no side effects when swapping pulleys out... However the replacment pulleys could have different timing marks, so if you wanted to verify the timng you would need to make sure the marks were in the factory positions
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
Steven_McKinley
Sep 5, 2015 10:48 AM
