Ground wire on top of tranny bell housing?
Old Feb 18, 2009 | 04:54 PM
jjwalker's Avatar
MECP Certified Installer
What does this wire actually do? in particular or is it just an engine to body connection? I found it hanging off on top of the bell housing not connected and I found the spade it goes to. I didn't notice anything different so i was just curious as to what its function is.
Old Feb 18, 2009 | 05:03 PM
eage8's Avatar
1308ccs of awesome
it grounds the engine to the body. it's important, you should plug it back in. If it's not hooked up that means it's grounding through something else that it's not supposed to like coolant.
Old Feb 18, 2009 | 05:18 PM
jjwalker's Avatar
I hooked it back up as soon as I noticed it missing. I havent been fooling around back there at all since I bought the car so I imagine it has been this way for a while.
Old Feb 19, 2009 | 01:40 PM
herrafass's Avatar
Any chance of getting a pic of the wire you're talking about? I just found a plug and a lil black box with an eyelet but I can't figure out where either goes.
Old Feb 19, 2009 | 02:15 PM
RotaryRocket88's Avatar
Top Down, Boost Up
That's the condenser for the oil pressure gauge. It attaches at one of the slave cylinder bolts, and is only there in the event that the gauge fails (so it doesn't fry itself).
Old Feb 19, 2009 | 04:29 PM
herrafass's Avatar
Thanks. Btw, sorry to thread jack.
rx7ali
Dec 12, 2015 06:00 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
PhillyFC
Aug 21, 2015 06:36 PM
