NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
Anyone know how to tune RX7s?
Old Feb 4, 2009 | 09:06 PM
Street Raider's Avatar
CT Anyone know how to tune RX7s?
Hey does anyone know any shops in CT that will tune a TII with Rtek? Im looking to get the timing and a/f ratios all set. I was thinking about using Rtek 2.1 i just need someone who knows rotary's.
Old Feb 6, 2009 | 07:46 PM
zachg88vert's Avatar
i am rotarted!!!!!!
CT
ive seen this members name around the fourms and havent heard a bad thing about him Kahren is his name. i believe hes from the hartford area
Old Feb 6, 2009 | 08:15 PM
vosko's Avatar
Just Call Me Terminator!
you can tune an rtek???
or do you mean with s-afc ???
Old Feb 6, 2009 | 08:49 PM
eage8's Avatar
1308ccs of awesome
rtek 2.1 has tunable fuel and ignition maps.
Old Feb 6, 2009 | 09:44 PM
vosko's Avatar
learn something new everyday
Old Feb 6, 2009 | 10:31 PM
Hitokiri_Gensai's Avatar
RHD ftw!
or bring it to Synaptic3 in New Hampshire.
Old Feb 9, 2009 | 01:31 AM
MattG's Avatar
MattG FTW!!!!!
why dont you just go with the rtek 1.8 with the 720's in both the P&S's
Are you running that much of a set up that you need to run a safc?
EDIT: I looked at you mods in your other posts, save your money and get the Rtek 1.7/1.8 Untill you get more money saved up. the Rtek will make your car scream without having someone to tune it, your not there yet. Also upgrade that fuel system!!! That can help you from running lean too.
If you need any help just holla.
Old Feb 9, 2009 | 09:06 AM
davedge's Avatar
They dont have a dyno, though.
Old Feb 9, 2009 | 12:23 PM
MattG's Avatar
MattG FTW!!!!!
You dont have to have a dyno to be able to tune it. Steve Kan doesnt use a dyno.
Old Feb 9, 2009 | 01:13 PM
davedge's Avatar
In order to fully tune a fuel or ignition map, you will need a good dyno with variable resistance(brake dyno...) so you can accurately tune each load cell, in each RPM range... this is fundamentals of tuning/using programmable engine management.
If not, it is more of "guesswork", and may work, for close to stock setups, but will not be as accurate, and will not run your motor with the same efficiency through all ranges/cells.
Old Feb 9, 2009 | 01:16 PM
will it be safe to run the 1.7 or 1.8? Will the car run like crap?
Old Feb 9, 2009 | 02:54 PM
MattG's Avatar
MattG FTW!!!!!
The 1.7/1.8 are made for set ups like yours. You are not running a powerful enough set up to justify the 2.1 In my opinion.
I am sure you have already read this, but this gives you a break down off all the features that the Rtek does.
http://www.pocketlogger.com/index.ph...age=1&ecu=S4T2
I think I have an Rtek 1.7 with a set of 720cc injectors if you are interested in them. I had them for mt TII FB, but then went a different route.
Azevedo
26
Mar 1, 2019 09:19 PM
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
