Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
autronic section
Old Jan 27, 2009 | 02:08 PM
turbodsm17's Avatar
autronic section
can we get an autronic section
Old Jan 27, 2009 | 11:13 PM
a7r's Avatar
a7r
There is one; it's hidden. Now that Ray Hall is out of the picture, they might bring it back.
Old Jan 28, 2009 | 09:09 AM
turbodsm17's Avatar
how can i view it?
Old Jan 31, 2009 | 04:59 AM
Evil Aviator's Avatar
Rotorhead
You are in it. Just post your question and make sure you type "Autronic" in the title.
Plus, there are various non-RX7 external forums such as these:
http://www.autronicforums.com/
http://www.mrm-racing.se/forum/
http://www.autronicforums.com/phpBB3/
Old Feb 3, 2009 | 11:03 AM
turbodsm17's Avatar
i dont really have a question. Im just trying to read up on it and how to configure it for the rotary engine. I havent been able to find any information on it in regards to rotary...
Old Feb 3, 2009 | 03:54 PM
Rotorhead
Well, the best information I can tell you about Autronic is that they generally tell automotive internet forums to remove any Autronic subforums, or at least remove them from public view. Therefore, you will need to go about searching for posts via a search engine rather than clicking on an Autronic link.
Since you apparently do not know how to use the Search function, here is a breakdown of the process:
1. Click on the Search button near the top right corner of the screen.
2. Click on Advanced Search.
3. Type Autronic in the Keword(s) box.
4. Right below that box change Search Entire Posts to Search Titles Only.
5. Click the Search Now button.
If you do not see a lot of threads, then it is possible that your Default Thread Age Cut Off is set too low. To fix this:
1. Click on User CPnear the top left corner of the screen.
2. Click on Edit Optionsfrom the menu on the left side of the screen.
3. Scroll down about 2/3 of the way and set Default Thread Age Cut Off to Show all threads.
4. Scroll all the way down and click on the Save Changesbutton.
Old Feb 20, 2009 | 08:06 AM
enzo250's Avatar
IRS Champion
Post any questions you have and i would gladly help out...
Old Feb 24, 2009 | 03:11 PM
turbodsm17's Avatar
My main issue at this point is just seeting up the software for the rotary engine.
Ive seen some people configure the software for a 12 cylinder, and others set it on rotary.
How would you reccomend dailing in the basic settings to run a rotary engine?
Old Apr 2, 2009 | 04:10 PM
full-cruise's Avatar
D.I.L.U.S.I.
dont they even have a auto tune in them?
Old Apr 4, 2009 | 07:32 PM
a7r's Avatar
a7r
It depends on the firmware you're running. v1.09 will run with the stock trigger, just configure things for 2 stroke/rotary, use the divider for your trigger configuration. With your coils and injectors disconnected, you'll have a pretty good picture of whether your configuration is right by running the scope and looking at the shape and position of things.
