torque brace question
Old May 21, 2002 | 01:40 PM
suprfast's Avatar
ive seen the TQ brace being sold, and i know that it is supposed to benfit from rocking and saving amotor mount or something. i did a search and just couldnt find my answer. here is the question. will the TQ brace help ease the 2nd to 3rd gear upshift? i seem to get a lot of 1-2-5 shifts and im not jamming gears at all. what do you guys think. one more thing, OT, when i went to ricks rotary, he told me that some bushings in the rear were bad, for the suspension. does anyone know which ones they are. i believe they are the spherical bearings. anyone have a part number?
kris
Old May 21, 2002 | 01:47 PM
martini's Avatar
the torque brace will help the 2-3 shift. That's mostly what they are there for.
Old May 21, 2002 | 03:37 PM
luneytune's Avatar
If thats true, where do you get them! I'm sick of the 1-2-5 look like an *** shift pattern.
Old May 21, 2002 | 03:44 PM
user 84205's Avatar
There are several companies that make them. Also there are several types, like RIKKI's they have them from the strut bar, the ABS area, off the actual strut bar, weld job, and other custom ways...
Old May 21, 2002 | 03:47 PM
user 84205's Avatar
shock style for over your abs...PIC its an S-13 though
http://www.hpi.co.jp/data/maxenginebk2.jpg
Old May 21, 2002 | 03:48 PM
user 84205's Avatar
looks like you put some work in RIKKI. Does that bracket at the fender side hold all that good? Hard to see....
Old May 21, 2002 | 03:51 PM
luneytune's Avatar
Originally posted by Dont_Be_A_Rikki
here is a pic
Coool!! I better get busy!
Old May 21, 2002 | 03:59 PM
user 84205's Avatar
hahaha thats pretty strong dawg....
Old May 21, 2002 | 07:10 PM
martini's Avatar
Or you can do it like this guy:
http://gt3540.com/pics/rx7/FD1_ENG2.JPG
and remove the airpump, and attach the brace to the bolts that the airpump uses. (you can't see it very well in the picture, I saw this car at Hot Import Nights and noticed the torque brace right away.)
Old May 21, 2002 | 07:18 PM
jspecracer7's Avatar
1JZ powered
let me tell you I made one from a strut brace and a 90* angle pc. of aluminum and it is rock solid never mis 3rd again kiss it good bye. I have had it on for 3 months or so and have yet to miss 3rd do it man do it....
HEY!!!! I did the same thing! Works great for shifting. Cost me a total of $6.00 in nuts/bolts and cutting blade.
Old May 21, 2002 | 07:21 PM
user 84205's Avatar
damn, I want to check it out, but I keep getting
a firewall...
Old May 21, 2002 | 10:00 PM
93TTRX7's Avatar
I just learned how to deal with the shift...I don't miss 3rd anymore and I just slam that bitch in there
Old May 21, 2002 | 10:08 PM
user 84205's Avatar
That guy has a BUTT load in that engine...He sure likes though steel braided hoses....
Old May 22, 2002 | 01:34 AM
Ninjak's Avatar
Martini, do you have any more pics of that guys engine?
Huy
Old May 22, 2002 | 03:19 AM
Pumped's Avatar
What????
how the hell do you guys miss third????
when you are on second gear, ALL you have to do is push the lever straight up.
man you guys better get a Automatic FD
Old May 22, 2002 | 08:31 AM
Hyperite's Avatar
Vagina Junction
Short shifter helps.
~Tom
Old May 22, 2002 | 08:33 AM
KZ1's Avatar
KZ1
Well, I fell in love with Chripsy's Tripple-R Reagon torque brace. Not for the 2-3rd shifts though. Just for the way it made the car feel. I swear it makes it feel brand new. all the slack is taken up from on and off throttle jerks, etc. running high boost, you can really feal the engine lock in on hard acceleration. RIkki's look good, I was so impressed I have done 2 group buys on it now, they are machined at a shop, etc and ready for install. Anyway, check it out. They moved the old archive out, so I can't reference there. but this one has some good info.
If you guys want one, I have a few left on this GB, and I know the RX-7 Store will be carrying one soon.
I have solid diff' bushings, the torque brace, and an aluminum flywheel. The drives bloody amzing. Just the shifting, throttle , eveything is improved.
Crispy's site
http://reganrotaryracing.tripod.com/powrbar.htm
Current Group Buy
https://www.rx7club.com/forum/showth...threadid=76319
Old May 22, 2002 | 08:35 AM
KZ1's Avatar
KZ1
almost forgot, a pic of it on my car.
http://www.ppiatl.com/engine2.jpg
Old May 22, 2002 | 10:02 AM
Wade's Avatar
Yeah I haven't missed a 3rd gear shift since about the first couple of months I owned my FD... if I had broken motor mounts or PPF it would be worse. Actually, my shifter started moving around too much and I found some of my PPF bolts were loose. Wonder how often that happens to others.
Wade
Old May 30, 2002 | 06:52 PM
What wld the advantages of having the shock absorber/damper type in place of the solid mount Torque brace?
