A self-draining clutch fluid reservoir?
My clutch reservoir will drain w/o leaving any evidece of where it is leaking! The slave cylinder is dry and so is the fire wall. Any suggestions?
Thanx,
sjeronymo@yahoo.com
Thanx,
sjeronymo@yahoo.com
I had a problem like this i couldnt figure it out because the slave cylinder was shooting the fluid back behind the transmission. All it was was making sure there was no air in the lines then double checking and seating the slave right and it stopped. It through me through loops too because I couldnt find where the fluids were going
When I have a hydralic leak like this and I can not find where it is leaking. I replace the clutch master and slave. If they were never replaced or both really old just replace both. If one is leaking now the other one is bound to leak sooner or later.
