Can I fit 19x19.5 + 55 wheels on my FD ?
Old Jan 6, 2009 | 08:48 PM
oneovakynd's Avatar
grip leak
CA Can I fit 19x19.5 + 55 wheels on my FD ?
Can I fit this on my lowered FD?
if not what do i have to do ?
Old Jan 6, 2009 | 09:53 PM
purerx7's Avatar
Registered User
I am going to assume you mean 9.5? If so, this will fit fine, you can always run a 5 or 10mm spacer if necessary.
Old Jan 7, 2009 | 01:08 PM
oneovakynd's Avatar
grip leak
all the way around? front and rear
Old Jan 7, 2009 | 02:30 PM
gracer7-rx7's Avatar
needs more track time
Talk to Rishie at AutoRND. He is local to the bay area and has done plenty of larger sized fitments.
Old Jan 7, 2009 | 07:48 PM
fdls6's Avatar
I think you'd be very close in the rear. My rear has 18x9.5 with 45mm ofset. There is about half an inch between the inside of the tire and the trailing arm. 10mm is almost a half inch. Up front, I would think you might rub on the factory spring. Might need smaller diameter springs such as a coilover would use. My fronts are 8.5 with +45. I can try to measure the distance between the inside of the tire and the stock spring later tonight if you'd like.
Old Jan 8, 2009 | 11:14 AM
oneovakynd's Avatar
grip leak
I have H&r springs on the car.
fidelity101
13
Aug 31, 2015 07:47 PM
