Drifting Discuss Drifting and drifting techniques here.
who makes angle kits?????
Old Dec 29, 2008 | 08:41 PM
leftcoastdrifter's Avatar
Dustin Becktold
i know mazdatrix offers a kit for 190 and it's a complet kit. GP sports does too but it's only half a kit or something? who else makes a kit or the FC?
Old Dec 29, 2008 | 08:59 PM
RussTII's Avatar
Veteran: Air Force
powered by max should be done with FC setup soon
Old Dec 29, 2008 | 11:26 PM
RE TurboII's Avatar
Meow
very soon. currently martin the fabricator has finished a set and is currently testing them. ill also be trying to get in as their next tester.
Old Dec 29, 2008 | 11:47 PM
stevensimon's Avatar
turbo 2 rotor on here makes modified spindles. they look awesome and im waiting on my set to show. massive angle increase
Old Dec 30, 2008 | 12:10 AM
ncastrignano's Avatar
RE for life
super now, they make tie rod ends. uras, they have hardened/ thicker tie rods. if u go to rhdjapan.com and look through all there stuff there are a couple others im forgetting i think.
Old Dec 30, 2008 | 03:28 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
I do, my kit works with the Mazdatrix and I believe the Super Now Heim ends. These pics are with only the modded spindles and your tires will barely hit the swaybar, remove the bar and add the spacers and you will hit the frame in front and LCA in the rear which is the most angle you can get without hacking up the frame rail.
Originally Posted by Turbo II Rotor
My modded spindle pics.
Stock
Modded
Stock
Modded
Stock
Modded
LCA Clearence
Sway Bar Clearence
Old Dec 30, 2008 | 07:00 PM
eyecandy's Avatar
I gotcha covered! Here are the Secret Element Superangle tie rod ends. Simple bolt on.
It looks like they deleted all my threads, LOL heres the details:
Features:
-Direct replacement of OEM rack ends
-High strength forged 4140 chromoly steel ball joint stud
-High strength forged 4118 chromoly steel ball joint housing
-Polished ball stud and nylon race for improved wear resistance
-Black print coat for corrosion resistance
-Longer outer tie rod end threading for wider range of toe adjustment
-Built for maximum steering angle of OEM rack
Below is a sample photo of what to expect for the increase in steering angle over OEM (pictured is the Super*Now FC3S Superangle tie rod end kit), the tie rod photos are the Miata, the RX7s are identical aside from the spacing and thread size/pitch.
I know there are some random threads/posts across the forum on the tie rods.
Right now the FC are on special for $100 shipped int he USA (limited time) while the FD and Miata is $145 shipped per set in the USA. I still ship globably. Any questions can be directed to seeltuned@aol.com
Queppa
Nov 18, 2024 03:47 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
