Haltech F-9 injector setup
Old Dec 19, 2008 | 08:05 PM
costas's Avatar
F-9 injector setup
Hi there ! does any one know if the F-9 can run different size injectors for primaries and a different size for secondary? someone told me that it can only run the same size injectors .
Thanks
Old Dec 20, 2008 | 12:24 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Thanks
Not true, just program it like you would any other haltech, set your staging injection mode, staging bar, and thats it.
However, i would honestly recommend you go with a newer more modern ECU in the end you will be better off.
PS. You'll need DOSBox to run that software, so go here:
http://forums.haltech.com/viewtopic.php?f=13&t=1817
And Here, if you use Vista:
http://www.youtube.com/watch?v=hH_A_...e=channel_page
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
