confused about EMS and j-spec motors
Old Dec 16, 2008 | 05:19 PM
alex91n/a's Avatar
i was thinking of getting a j-spec turboII motor, but i have done some research and have heard that if you get a j-spec motor that you will need to get a new EMS. but would i haveto get a new EMS if everything on the motor is j-spec. the reason i ask is because i really cant afford a new EMS right now seeing as im only 17. any help is much apreciated.
Old Dec 17, 2008 | 09:43 AM
Aaron Cake's Avatar
Engine, Not Motor
Nope. The ECU is the same. If you are swapping a TII engine with a J-spec, it is basically plug and play.
If your car is an NA, it's another story.
Old Dec 17, 2008 | 01:43 PM
alex91n/a's Avatar
well right now my car is n/a but i wanted to get a turbo II
Old Dec 17, 2008 | 02:05 PM
Aaron Cake's Avatar
Engine, Not Motor
Since you are starting with an NA, you will need the TII ECU, AFM, pressure sensor, emission harness (or modify yours), TII transmission, TII driveshaft, TII differential, TII half shafts, TII starter, TII clutch slave and a few other things I may be forgetting. See the 2nd gen FAQ for turbo swapping information.
Old Dec 17, 2008 | 02:11 PM
alex91n/a's Avatar
oh ya the motor im looking at comes with all that stuf... or at least most of it. i was just slightly confused cause i herd if you have a j-spec motor with j-spec everything you need to get an after market stand alone. thanks for the help though
bryancmatthews
Power FC Forum
Sep 5, 2015 03:57 PM
doritoloco
Sep 5, 2015 12:41 PM
