help needed me noob (wont rev past 3400)
Old Dec 6, 2008 | 08:06 AM
azracer's Avatar
Newbie
umm yeah i bought an 1986 rx7 the engine is the 13b and the car wont rev past 3400rpms in second gear and on it will in neutral and in 1st and ideas what could be wrong???
i replaced the maf and tps thanks ahead of time for the help
Old Dec 6, 2008 | 09:38 AM
IanS's Avatar
Ricer
If you notice I edited your thread title. This extra information will help you in the future so others will know your problem. This is also beneficial for others when using the search function to find other threads that may pertain to their problem as well.
Old Dec 6, 2008 | 09:53 AM
Aaron Cake's Avatar
Engine, Not Motor
Test the boost sensor as per the instructions in the FSM.
Old Dec 16, 2008 | 02:29 PM
azracer's Avatar
Newbie
no boost it is na
Old Dec 16, 2008 | 04:31 PM
Aaron Cake's Avatar
Engine, Not Motor
It's called the "boost sensor" regardless. On the TII it's called the "pressure sensor". Go figure.
Look it up in the FSM and then test as per the instructions.
Old Dec 25, 2008 | 09:40 AM
azracer's Avatar
Newbie
k ill check thanks
zuesskroph
Aug 13, 2015 06:05 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
