how to remove sound/ tar from floor
Old Dec 4, 2008 | 01:39 AM
78Savanna's Avatar
CA how to remove sound/ tar from floor
I want to reduce my cars weight. I was told that the sound deading material/ tar weighs a lot... What is the best way to remove it?
Old Dec 4, 2008 | 09:01 AM
Aaron Cake's Avatar
Engine, Not Motor
Kerosene removes it very easily. Just be careful.
However if you remove it, the car will now sound like a tin can. If you are daily driving the thing I suggest you leave the tar in place. It really doesn't weigh that much. Only about 20 LBs.
Old Dec 4, 2008 | 12:28 PM
78Savanna's Avatar
thanks
For only 20 lbs i guess it is not worth the hassle. Thanks
Old Dec 6, 2008 | 04:18 AM
DrFtKiNg240sxy's Avatar
you can also use dry ice. Just let it sit on top and chisel away after a couple minutes. Its WAYYY easier
Old Dec 6, 2008 | 09:57 AM
Aaron Cake's Avatar
Engine, Not Motor
Honestly, I've done both and kerosene is by far the easiest method. Just brush it on, then scrape off the goo with a putty knife. It's easier to keep kerosene as well since it doesn't sublimate.
Old Dec 7, 2008 | 12:43 AM
78Savanna's Avatar
CA
When I was stationed in North Dakota, it got down to -103degrees and I remember it all that material would just crack and peal off. Maybe I should make a road trip up there in the winter.....LOL.
Old Dec 7, 2008 | 10:31 AM
Fuergrissa's Avatar
Newbie
you make it sound like anyone could just go to ND anytime durring the winter and encounter -103 weather. and if it were that cold I would probably have other worries besides the sound deadening in my car =)
Old Dec 7, 2008 | 02:26 PM
rowtareh?'s Avatar
I Dislike Everything
-103* is not even survivable conditions for a human being. Your skin would freeze in a matter of seconds.
I never thought kerosene would work though, is it that corrosive??
Old Dec 7, 2008 | 10:33 PM
evofd3s's Avatar
dry ice is most effective as i had used it and a lot of those honda guys had great results with them as well.
Old Dec 7, 2008 | 10:38 PM
Zanity's Avatar
Zoom Zoom Baby
i would say the cakeman is right since he seems to be the only one saying he has done both. but since guys not doing it doesn't matter. good for future reference though.
Old Dec 8, 2008 | 09:32 AM
Aaron Cake's Avatar
Engine, Not Motor
It just dissolves the tar and turns it into a goo. The only annoyance of course is that it is flammable.
Old Dec 8, 2008 | 09:45 AM
CosmoQuik's Avatar
busted in here eye
way more then 20 pounds i removed over 70 lbs from mt rx7 with dry ice, aaroncake ur forgetting about the stuff under the car as well, kerosene is way bad dry ice is very effective and less mess
Frisky Arab
Sep 4, 2015 06:17 PM
