new member and mazda owner needs help
Old Nov 30, 2008 | 03:01 PM
truenodrifter's Avatar
i just got a fc turbo two for $200.00 and it wont start. it turns over but wont crank? im thinking it might be the plug wires in the wrong pattern? any help? any would be great!
Thanks, Dany
Old Dec 1, 2008 | 09:52 AM
Aaron Cake's Avatar
Engine, Not Motor
Turning over is the same thing as cranking. You turn over/crank the engine with the starter to start it up.
I think you mean that you can crank the car but it won't start?
Do you have fuel? Pull the plugs and check for wetness.
Spark? Disconnect a plug wire, shove something metal into it (old spark plug) and place it near a ground.
If you have both fuel and spark it's probably just flooded.
Th0m4s
Feb 26, 2019 02:04 AM
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
