Power FC putting stock ecu back in, quick question
Old Nov 29, 2008 | 10:53 PM
JEDlocks's Avatar
Vagina Destroyer
Is it ok to put the stock ecu back in even though my car is street ported? My pfc is untuned and I want to put the stock ecu back in so I can install my main cat and pass smog. (Not enough money for a tune)
Old Nov 29, 2008 | 11:17 PM
cewrx7r1's Avatar
Eye In The Sky
That it not logical. The stock ecu is made to run a stock port engine with all stock equipment attached.
It might if all cats, stock injectors, air pump, etc were on the engine and in perfect working order.
Is this the case, or are you expecting a miracle?
You might have better results running E85 and just tuning enough to pass the tests.
torky007
Aug 17, 2015 05:14 PM
