Ignition Switch with Key How Can I replace
Old Nov 28, 2008 | 06:26 PM
mckinney1975's Avatar
Newbie
CA Ignition Switch with Key How Can I replace
Key broke off in Ignition bought new how do i get it out without taking the whole unit of the sterring wheel?
Old Nov 28, 2008 | 11:08 PM
misterstyx69's Avatar
Retired Moderator, RIP
You Can.In a way.replace the whole column with the ignition switch On it.But the ignition isn't that hard to change,once the surround is taken off.ON Sec gens the ignition is Riveted on(they use Rivets instead of Bolts.you drill the Rivets and Presto,teh ignition pops off,replace and Hook up the connector and you are done.Just be sure to Disconnect the Battery before Venturing into any Wiring.It is Rule ONE,never do any Wiring repairs,modifications,splices,etc without Disconnecting the Battery..Good Luck.STYX.
Boriquaguerrero
20
Apr 22, 2019 01:15 PM
Joe428
16
Aug 19, 2015 06:24 PM
fastsaab
Aug 19, 2015 11:42 AM
