90 vert - no high beams
Old Nov 27, 2008 | 08:44 PM
d-man's Avatar
I've got an odd problem I'm having trouble isolating and couldn't find in the FAQ's. All lights on my 90 vert work fine except the high beams. I've checked the dimmer relay out under the hood and it tests out fine. I thought it might be the switch on the turn signal stalk, so picked up one on ebay, but still have the problem. Confirmed that the bulbs themselves aren't the issue, so not sure where to go with this from here. Can live without high beams, but I'd like to fix if I can.
Ideas ?
Old Apr 6, 2009 | 06:33 PM
d-man's Avatar
Any thoughts on this ? Car just failed state inspection because no high beams.
Old Jun 3, 2009 | 04:06 PM
kiker14's Avatar
finally back in an RX-7!!
I'm sorry I can't help, but my '90 vert also does not have working high beams, although I haven't done any troubleshooting yet. Hopefully this bump will get somebody to chime in, if not - I will report back after I investigate.
Old Jun 7, 2009 | 08:42 PM
d-man's Avatar
Thanks for the bump and good luck with the troubleshooting on yours. For what it's worth, I was told the most likely issues are the relay under the hood or the cpu. I picked up a used (but supposed to be tested) cpu and plugged it in 2 days ago, still no highs. I had taken it to a shop, not Mazda, and they thought cpu also. Bad news is a new one is over $300 bucks and not sure it will fix the problem. Thinking of looking into a way to direct wire between turn signal stalk and dimmer relay and bypas all the other crap, but I'd rather put it back like original. Sucks to be missing summer driving just because of stupid high beams.
Old Jan 23, 2011 | 09:23 PM
hoofhearted's Avatar
Photon co-inventor
The flash-to-pass works while the headlights are down when one pulls on the dimmer switch.
With the headlights are up and turned on, I grounded the dimmer relay and the bright lights come on. This tells me the problem is not the headlights or the relay.
Next, back from the relay towards the ignition switch, is the cpu. How does one test this?
I have access to a 91 FSM but the car in question is a 90 vert with an airbag.
I suppose if one finds the wire in to the cpu, from the dimmer switch on the steering column, and grounds it, thus emulating what the dimmer switch send into the cpu. If the cpu is good, wouldn't it send a ground signal to the relay (which works) and that should dim the headlights?
If the cpu is good then the next culprit might be the dimmer switch on the column. This is a relatively simple switch even though it does have the turn signal switch in it too.
Is there a difference between the 90 vert with airbag and the 91 vert with airbag?
Peace
Old Jun 16, 2015 | 08:58 PM
Apoc3D's Avatar
FL
I know this is resurrecting a very old thread, but I'm having this exact same problem on a 1990 vert. I don't really care all that much since I don't have inspection or anything here in Florida, but I'd still like it to work if possible. My flash to pass works when the headlights are down, all of the other lights work, just no highs! Any help would be greatly appreciated.
Old Jun 19, 2015 | 01:14 AM
misterstyx69's Avatar
Retired Moderator, RIP
there is a HI/LO relay at the Front of the car.
See the manual and replace it.
Foxed.ca
Old Aug 13, 2015 | 12:48 PM
Opposite Lock's Avatar
1991 S5 N/A Vert
Check out this work around thread for a quick fix for your inspection:
https://www.rx7club.com/2nd-generati...ights-1066826/
Donald Hampton
16
Nov 23, 2022 06:38 PM
wa11yba11s
Oct 16, 2015 09:54 AM
The1Sun
Sep 7, 2015 10:21 PM
