Help 90 rx7
Old Nov 26, 2008 | 02:25 AM
randydru's Avatar
Newbie
KY Help 90 rx7
I have a 90 rx7 vert automatic , will start and idle all day, but sometimes when you try to accelerate it stalls. new plugs wires, fuel filter and fuel pressure is good anyone have any ideas
Old Nov 26, 2008 | 09:17 AM
Aaron Cake's Avatar
Engine, Not Motor
Fuel pressure is constant even when it stalls?
Does it misfire at all first or just die? Any other symptoms?
Old Nov 26, 2008 | 05:18 PM
randydru's Avatar
Newbie
KY 90 rx7
yes fuel pressure is constant and no it does not miss or cut out just dies if you over accelerate
Old Nov 27, 2008 | 09:00 AM
Aaron Cake's Avatar
Engine, Not Motor
Test the secondary injectors as per the FSM.
At what RPM does the car die? At what throttle level?
Th0m4s
Feb 26, 2019 02:04 AM
