clutch problem?
Old Nov 18, 2008 | 05:49 PM
Dedlyvirus's Avatar
clutch problem?
hey guys, i have an 86 rx7 gxl and i was driving it the other day, at first i noticed that the clutch pedal was sticking a little bit when i was releasing the pedal. But it got worse and eventually when i pushed the clutch in, the pedal went all the way to the floor and stayed there. When i pulled the pedal out, i could start the car without the pedal being pushed in. If i tried to put it in gear, the gears would grind. Is it the clutch? the master and slave cylinder? or something else in the tranny?
Old Nov 19, 2008 | 10:14 AM
Aaron Cake's Avatar
Engine, Not Motor
Check fluid levels.
Though you'll probably find a bad cylinder. Best be is to replace both the master and slave cylinder, along with the hydraulic hose that connects to the slave.
Old Nov 21, 2008 | 01:16 AM
unrealanthology's Avatar
linkage possibly
Old Nov 21, 2008 | 09:29 AM
RotativoRx7's Avatar
FL lost pedal pressure
most likely you lost your slave cylinder, or the master cylinder, like the guys said also you may want to replace the hose for a new one, old ones tend to leak and expand causing pedal pressure loss, use dot 4 brake fluid, and dont drive the car like that, u will mess up the clutch if it was good or mess up the tranny grinding gears,good luck bud.
Old Nov 21, 2008 | 10:17 AM
Aaron Cake's Avatar
Engine, Not Motor
There is no linkage, only a lever in the bellhousing. It has been known to pop off but that's rare.
Old Nov 21, 2008 | 12:22 PM
adidastrip's Avatar
My guess is leaking slave or master cylinder. I just replaced mine for the same reason. It could be leaking lines but that isnt as common.
Old Nov 21, 2008 | 07:06 PM
thenuge's Avatar
PA i know same happend to me
dude its your clutch deffinatly the same thing happen to me i let my cuz drive he did a burn out fried the clutch when you take it out the whole back end of the clutch will be down to the rivits for real
Enzo1944
Sep 6, 2015 08:57 AM
vmerino
Sep 5, 2015 11:26 AM
