Official Compression Numbers From Mazdas Spec Book!!
Old May 15, 2002 | 04:07 PM
RotorMotorDriver's Avatar
Seven Is Coming
Ok, I know a lot of people (including myself) have been looking for compression numbers. Well, I just happened to find in some spec books from Mazda, the proper compression numbers. Heres what it says:
Displacement:
12A Engine - 573 CC (35.0 cu-in) x 2 Rotors
13B Engine - 654 CC (40.0 cu-in) x 2 Rotors
Compression Ratio: 9.4:1
Compression Pressure Limit: 600 kpa (85 lb/in2) at 250 RPM
Max permissible Difference Between Chambers: 150 kpa (21lb/in2)
So there you go boys and girls, take it as you wish, but thats the numbers Mazda threw out there.
~T.J.
Old May 15, 2002 | 07:06 PM
Max7's Avatar
Admitted Sevenaholic
Sadly those numbers won't work for and engine that cranks at 300RPM
Old May 15, 2002 | 09:28 PM
Directfreak's Avatar
I am a Jeeper Now.
How does one know what their cranking RPM is? If it cranks at a higher RPM, wouldn't that mean that compression is lower?
Just curious.
Old May 15, 2002 | 10:24 PM
Max7's Avatar
The Mazda compression tester will have a display showing what the engine RPM is/was at the time of the reading.
The higher the RPM, the more the seals are pushed to the rotor walls, kinda why a rotary has such low compression at low RPM and the need for the E-Brake as the motor can still spin over while parked on a slight incline in gear
Old May 16, 2002 | 12:20 AM
Seven Is Coming
Well, thats what it said . I just thought Id pass it along incase anyone wanted to know...Just thought Id be nice .
~T.J.
Old May 16, 2002 | 12:41 AM
Max7's Avatar
here is what mine came out to a month or so ago around 104k on her.
Front 7.3/7.5/7.3 - 341 RPM
Rear 7.5/7.7/7.9 - 348 RPM
mazdaverx713b
19
Aug 29, 2015 12:30 PM
elfking
Aug 19, 2015 09:48 PM
