Drifting Discuss Drifting and drifting techniques here.
"drift knob" install
Old Nov 10, 2008 | 06:34 PM
RotaSpinna69's Avatar
"drift ****" install
Purchased the Cusco drift **** for the parking brake. Purchased from Touge Factory and no instructions came with it. If anyone has any information I would be grateful.
Thanks,
Andrew
Old Nov 10, 2008 | 06:59 PM
NoPistons!'s Avatar
Tango Down
Are you serious?
If it's anything like the push-spin **** you can get on ebay for $5 you just push it in where the button goes, you dont remove the button, just push it in over it.
http://www.frsport.com/DiF-Drift-Spi...ob_p_1040.html
Old Nov 10, 2008 | 08:13 PM
I just wasn't sure if it was to be pressed in, screwed in somehow, or if it replaced the factory button.
Thanks,
Andrew
Old Nov 10, 2008 | 08:14 PM
NoPistons!'s Avatar
Tango Down
No problem. I know the 350z is a bit different but everything else is "push it in".
Old Nov 11, 2008 | 10:09 PM
xzyras's Avatar
I don't have 3rd gear
Hey dude, it's pretty easy. I'm sure you can figure it out. You unscrew yours. Remove the spring, and screw in the new one. Done deal, pull up the e-brake and pull the button out to lock the e-brake. That's all there is to it.
Old Nov 11, 2008 | 11:38 PM
blimp's Avatar
ya just use some pliers and twist the old button offf.
Take the spring out and screw on the new cusco button.
Old Nov 12, 2008 | 11:08 PM
dkwasherexd's Avatar
Garage Life
damn I still need one of these. Sometimes i forget to let the ebrake all theway down lol
Old Nov 13, 2008 | 12:58 AM
Twins80s's Avatar
I
i do that 9 times out of 10. thats why i dont play with the ebrake anymore lol
Old Nov 14, 2008 | 08:58 AM
MtnFC3S's Avatar
anti-pistons
i got one off ebay for less than $10 shipped. it definately keeps u from leaving the ebrake half engaged when u drift. worth every penny.
Old Nov 14, 2008 | 07:44 PM
barcode's Avatar
Which eBay one did you get? Or do the 240sx ***** fit FC's as well?
Old Nov 14, 2008 | 09:01 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
I just stick a paper clip in mine.
Old Nov 17, 2008 | 08:55 AM
MtnFC3S's Avatar
anti-pistons
the ones for the 86 are the same as the FC. At least with the one i ordered it was. u just unscrew the old one, take out the spring, then screw in the new one.
Old Nov 17, 2008 | 01:07 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
what about for the FD?
Old Nov 19, 2008 | 01:12 PM
Well the one I purchased isn't threaded. So I can't "screw" it in...
Old Nov 19, 2008 | 01:31 PM
blimp's Avatar
you got the wrong one. They gave you a 240 one. I went through the same thing. You gotta make sure they are giving you a fc3s ****.
Old Nov 20, 2008 | 09:19 AM
NoPistons!'s Avatar
Tango Down
Or see if it will fit over the stock button and still go into the handle......
I'm with turbo II rotor, stick something in there.....
My ebrake button shot out one day in my 626 so i said f-it. Buy some wheel choks.
Old Nov 20, 2008 | 09:40 AM
Japan2LA's Avatar
It should be thread.. 5mm metric thread..
Get the correct part, made for the FC3S.
I have them
Link:
https://www.rx7club.com/2nd-generation-rx-7-1986-1992-parts-194/fc3s-drift-e-brake-button-f-s-800540/
Old Nov 20, 2008 | 04:14 PM
Those are some shiny eggs Brian.
Old Nov 21, 2008 | 11:25 AM
I have them
Link:
https://www.rx7club.com/showthread.php?t=800540
You have a PM
Old Nov 22, 2008 | 04:50 PM
Japan2LA's Avatar
Originally Posted by RotaSpinna69
You have a PM
Just waiting on payment..
Old Oct 13, 2011 | 04:41 PM
Slideways Driver's Avatar
Hahaha I use a penny and tape wen I slide I just slide the brake cover down. So the button gets held down.
Old Oct 13, 2011 | 04:57 PM
driftfcbuckey's Avatar
RX7-Factory
i never liked these things. they would sometimes lock them selves partially up.
i removed the handle, the rod, and spring, and put tape around the drift button and pressed it back into the ebrake, and left it.
when you need to park, and lock the ebrake, there's a little catch you can easily just flip down to lock, and just pull the ebrake up like normal whenever you want to release it.
Old Oct 13, 2011 | 04:58 PM
RX7-Factory
holy **** thread revival guy....
Old Oct 13, 2011 | 06:15 PM
OC DEBO's Avatar
definitly a revival, but I'm still with the guy who asked about the application for the FD....
Old Apr 10, 2012 | 07:54 PM
A Simple MX6's Avatar
As far as I know, it's the same application.
Contact Japan2LA, I feel like he's sold them and they were for both the FC and the FD. I could be wrong though, considering I don't need to keep up with the FD.
I've enjoyed mine, definitely a lot easier than the stock one. I have accidently tapped it while releasing, and it ended up staying engaged, but that was just once, and user error.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
doritoloco
Sep 8, 2015 07:58 PM
vmerino
Sep 5, 2015 11:26 AM
