tps quickie
Old Nov 10, 2008 | 01:35 PM
Red Sidewinder's Avatar
Shiranui
Question tps quickie
quick question,..is it worth while switching out my s4 tps sensor for an s5 tps sensor? b/c i am still having an erratic idle problem, and i want to try this.
motor is an s5 with an s4 tps sensor, i was wondering if that could be the cause of the erratic idle problem. what are you thoughts?
Old Nov 14, 2008 | 09:25 PM
jmkogut's Avatar
No, the TPS is not the same between S4 and S5 RX-7's.
http://mazdatrix.com/86-92Electrical-Chassis.htm Check the TPS section.
You can post a WTB here: https://www.rx7club.com/2nd-generation-rx-7-1986-1992-parts-194/
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
